buck1013
- 0
- 0
- coldwater, ms
I need help with my deuce.
The other day I drove my deuce to one of my friends house. I had no problems. When I cranked my deuce, it sounded very weak, but cranked on the the first turn, of course. On the way home my guages were twitching and my lights would not work. The next day I did some investigating and found that one of my battery cable ends had melted (no corrosion) where the bolt that hold the cable eye on the end. I made a new cable and crimped on the end with a hydraulic press (ground cable). Turned the power switch to the on position, and the beast tried to turn over without pressing the starter button
. Assumed it might be the starter solenoid and took off the starter and had it rebuilt. Put it back on and plugged the starter button back in and same thing happened. I know I should have replaced the button, but the starter had stripped bend-ix gear and other problems, so they say. Might there be a wire grounded between the started button and the starter?
