Electrical problems
borky51
Hartland WI
I have a problem not me my deuce, When I put the lights on everything works then when I put the turn signals on the lights go out and I have to rest the light switch. My directional don't flash I put a new flasher in When the air pressure is low the directional work when I turn them on and off manually the directional lights don't flash but go on. I'm stumped does anyone know what the problem could be or where to start. please help Borky
Jeepsinker
402
Dry Creek, Louisiana
You are tripping the circuit breaker in the switch. You need to inspect your harness for a short to ground. Check mainly around all four signal lamps back up into the frame, and check under the dash around the steering column.
