embossed directions on transmission
YkDave
Yellowknife, NT. Canada Eh?
the pieces are a matched set to the engine
If you were to swap parts around, you would need to check clearances and runout(apparently the casting/machining tolerances left a bit to be desired LOL). much easier to just keep everything matched together.
Its all over the manuals too "keep as an assembly with engine"
