Emergency Air Brake Service Line Broken on M931A2
Retiredwarhorses
4,121
Brentwood, Calif
Question
I just won an M931A2, in the video I see the front left Emergency Gland Hand unit is completly missing...the truck is running and it is dumping out Air...When I go to Pick it up, can I just cap it off? I thought about just taking the one off my 923 when I go to pick it up and install it to get it home....truck also has one rear flat tire...I hope its not worse then a Leaky CTIS assy on that tire...I will bring my Air hose to air it up..or should I just try and use the CTIS Compressor?
Suprman
680
Stratford/Connecticut
There is no ctis compressor. It takes air from the primary air system I believe. If you have an open glad hand leaking air and the valve going to it is broken (not like the valves are reliable anyways) then you need to cap it. I would bring a few different size caps and plugs just in case and the air line to fill the tire just in case the ctis won't air it up.
