Engine data plate question
dirtyfingernails
Gainesville, FL
Could someone please post a picture of their Hercules multifuel engine data plate (the one to the right of the turbo? Mine is very faded and all I see is Hercules at the top and the numbers 2-90 stamped into it. Lower down is another number 3995322 which I'm guessing is a serial number for the unit. It looks like maybe a rebuild tag. Thanks!
Steve
1,131
Kind of blurry, someone out there may have a better version.
dirtyfingernails
Gainesville, FL
The reason I asked for the photos is obvious in my picture. I can barely see Hercules and below it Multifuel. The the right is 2-90 and below a serial number is stamped in also. I noticed that none of these tags indicate which engine type you have. How do I determine that (i.e. is it an LDT 1C or 1D? etc). Is that data plate somewhere else? Thanks.
Steve
dirtyfingernails
Gainesville, FL
Crap I see it now on the other tags posted--the engine type that this. Sorry to have posted before looking more closely. Well, since I obviously can't read my data plate, is there another way to determine the engine type?
FormerNewMVGuy
10
stockton NJ
Well on my plate the type of engine is the first number directly below where it says multifuel just to the left. And i belive they are all the same ,The tags that is .yours is just extremely worn off. If you zoom in on mine you can see wear it says model ldt 465 1D
1,178
Directly under the first U in the word MULTIFUEL, is the 1C or1D designation(blank space with stamped info) As for which one you have, it don't really make any difference unless you need to do some major repairs on it. I think the head torque specification may be slightly different but that's all i can think of right now.
