Engine hrs?
Duckduckdeuce
California
Engine hrs! Is 1900 hrs. A lot for a m35a2 multifuel engine? What should have been done or need to be done at this many hrs. Im looking to buy a m35a2 and most say around 700 to 900 hrs. So not to sure about buying one with 1,900 hrs on it. Any help on this subject will be great. Thank you!
porkysplace
1,493
mid- michigan
Hours and mileage are pretty much meaningless on military vehicles since when there is a issue with the hour meter/odometer the military just swaps in a new one. Unless the current owner has verifiable service records you should plan on a full service (oil change, fuel filters, grease job, full brake inspection , replace wheel bearings ect.) if you get one.
This is a good source for leaning what to check on a M35A2
GTA-9-1-1851-8.pdf M35 complete diagram of with descriptions of all components.
It is also a good idea to read the operators TM before buying.
TM9-2320-209-10-1.pdf
TM9-2320-209-10-1 Operation, Installation and Reference data for the M35 series, Operator Level.
these are operator level maintenance TM's which will help you know what to expect for routine maintenance needs.
TM9-2320-209-10-2.pdf
TM9-2320-209-10-2 Scheduled Maintenance Operator level M35 Multifuel.
TM9-2320-209-10-3.pdf
TM9-2320-209-10-3 Troubleshooting Operator level M35 Multifuel.
TM9-2320-209-10-4.pdf
TM9-2320-209-10-4 Maintenance Operator Level M35 Multifuel.
Add the lube order.
LO9-2320-209-12-1.pdf
LO9-2320-209-12-1 Lubrication Order for the M35 series.
The more you educate yourself before buying , the better chance you have at getting a good truck at a fair price.
