Engine Identification Help Needed
msisco
Costa Mesa, Ca
Here are numbers I could read off the engine data plate and some pics. Does anyone know what this is and it's age?
model LD?-455-1D (sorry, dirt covered up the model in the pic I have)
Contract No.
DAAEO7-87-C-J069
PART NO.
12354301
SERIAL
3994584
ADERTISED HP
134 @2600RPM
VALVE LASH
INTAKE .010
EXH.
.025
INJECTION TIMING
20 DEG. BTC
FIRING ORDER
1-5-3-6-2-4
Thank You!
wsucougarx
65
Washington State
LDS-465-1A was the standard multifuel found on the 5 tons of the day
Looking at the pics on the dataplate, wondering if it's an LDT-465-1x b/c of the 134 HP rating
The contract # for the engine indicates 1987. So one would assume it is a 1987 and later engine
Can you make out the dataplate on the IP? It will also indicate if it's and LDS IP
wsucougarx
65
Washington State
Here's the standard LDS-465-1A dataplate that I have seen on the LDS'. Not sure if there are other formats out there but this is the only one I've seen. Did any of the 5 ton MF come with the LDT engine?
