Engine mounts
bajaman
15
San Diego Ca
Hello does anybody knows the part number of the engine mounts for a 1028 I’m looking for engine and transmission mounts maybe an upgrade, where should I buy them ?
Thank you I always trust the knowledge here
87cr250r
2,061
Rodeo, Ca
Energy Suspension inserts are good. You need to make sure you get the right engine mounts. There are two options, 3.1116 and 3.1152. If I remember correctly you need to use the 3.1152. They both fit the clamshells but one insert is smaller which causes the engine to sit low in the mounts.
Some googling confirms you need to use 3.1152. It's the mount for a 2wd 454 Suburban.
