Hello All, I have a 465 Multifuel engine, with the turbo off of it now, (in a box), engine has the engine data plate completely faded to metal. The only numbers that are visible are stamped into the engine's data plate: 3871149
also, the casting on the passenger side of the engine block has the following numbers cast in to it: 11610199 and: 7 9 70, (which I figured to be the date?)
Not far behind the generator there is a casting for TD, which may mean that it is a thick deck block. I do not know if this is a Continental, White or Hercules engine, the start is mounted on the passenger side of the engine as well, the truck itself is a Kaiser Jeep 1970.
My question is to all the knowledgeable individuals out there: is it a LD, LDT, or LDS engine and what make/ version is it, if possible to identify from the engine #, cast or stamped in.
Any help and ideas in this is greatly appreciated.
Thank You.
ALFA2
