Engine on MEP006A/115A 60kw
NEIOWA
127
NE IOWA
What engine is in these gensets. Duece engine (White or other). Or is it a engine unique to the genset? AC perhaps???
Info from the -12 if helpful to recognizing.
b. Engine. The engine is a liquid-cooled, 6 cylinder, valve-inhead,
4 stroke cycle, turbo-charged, diesel engine.
COD drawing no. . . . . . . . . .70-1049
Firing order . . . . . . . . . . . . . . . 1-5-3-6-2-4
Rotation (viewed from fan end) . . . . . . . . . . . . . . . . Clockwise
Type: 6 cylinder, turbocharged
Cooling . . . . . . . . . . . . . . . . . . . . Circulating coolant
Cycle . . . . . . . . . . . . . . . . . . . . . . 4 stroke
Valves . . . . . . . . . . . . . . . . . . . . . 2 per cylinder
Maximum permissible exhaust
restriction . . . . . . . . . . . . . 2 inches of mercury
Brake horsepower
CAUTION
1500 rpm . . . . . . . . . . . . . 100
1800 rpm . . . . . . . . . . . . . 120
2000 rpm . . . . . . . . . . . . . 130
NEIOWA
127
NE IOWA
Re: RE: Engine on MEP006A/115A 60kw
doghead said:
Now anyone know where else this engine is (was used) milspec only? or a varient on their diesel tractors of the (60s? 70s?). I'd guess not designed/made only for the mil but perhaps a variant of a tractor engine. Local FD is stuck with some 400hz MEP117 they need to recover their freight $ (did not know they were getting 400hz units). I'm recommending they pull/sell the engines and send the residue to GSA for auction.
acetomatoco
RE: Re: RE: Engine on MEP006A/115A 60kw
yup, you beat me to it... good old Allis Chalmers.. made two or three different sized in line Diesels used in gen sets for the gummint. I may even have a new turbo around here somewhere for one.
