engine problems
germandriver
germany/gelsenkirchen
hello frinds at first my english is verry bad im sorry about that but i hope you understand me
my m109 has an multi fuel engine and i need new kabels from the injektor back to the tank i aks all dealers in germany but no boddy can help me
thanks four the help
gringeltaube
Staff Member
2,687
Montevideo/Uruguay
Welcome to Steel Soldiers!
1) No "Kabels" anywhere, between fuel injectors and fuel tank...
2) If you want to be helped you need to be a bit more precise describing that part.
Why not start downloading and reading all the good books in this section... Then post lots of questions - and possibly useful info, too - and you will see your English improving gradually, automatically...!
For example TM 9-2320-361-20P, Fig. 17, shows all the fuel lines and tubes which are directly attached to the engine.
Same TM, Fig. 25 has every line and related parts, between engine and fuel tank.
Then, with the manual in hand try to identify that item you are looking for.
Surely someone here can help you out if you give us a part number, or possibly its NSN. Or at least take a photo.
G.
germandriver
reomie dont have it i was today by a workshop they works with pneumatiks and hydrauliks they have a idea an give me parts i try it at the weekend if it works i post pictures
i hope i can find the way to post it
germandriver
Thanks for the email addresses. Just got me some help with the language.
I tried to fit the parts together that I was given last time, but it didn't work. American and German "inch" just doesn't go together. In the end I had to take the original part to the shop and they are trying to order something that might fit. If it does work out, I'll post pictures - if I have worked out how.
