ENGINE RUNING TEMP
24-VOLTS
Hey Guys,
Just checking to see engine water temps you are running ?
My engine temp is normally 180 or so. But installed the grill cover and she went up to 200. And seemed to run much better at that temp then the 180. So just thinking my thermostat is too cold and may should be a bit warmer.
Phill
jwaller
20
Columbia, SC
I try and keep mine at 200 with cover on almost all the time. it is hard to keep these eng's at temp bc of the size of the cooling system and the efficiency of the motor
