- 706
- 975
- 93
- Southern Minnesota
Was wondering if anyone knew how fast the engine needed to be spinning for the 200 AMP generator, to actually output 200 AMP - 24V?
I'm assuming there is some sort of rule for shelter carriers or other similar high amp users to pulling the throttle out and having it enough to power various usages.
I've got a wild idea to buy a 24V - split phase inverter, hook it up via the NATO Slave port to the rig and use that either for camping or as a 'generator' for the house in the event of a power outage. Figure a 5000 or 6000 watt, 240V split phase would be enough power.. and is close to the 200 AMP - 24V (as long as I don't run it maxed out) that it would be able to power anything I need.
(I've looked at 240V split phase generators in the same wattage range, and none of them seems to be clear on power. They use the RPMS of the generator to handle the 60 Hz... an inverter would provide MUCH cleaner power, should it be needed.)
