engine swap
91W350
60
Salina, Kansas
You will have to buy or build engine mounts and the transmission adapter. The 715 is pretty unique, nothing is really common on them.
bcowanwheels
KINGSPORT, TN.
best & most economicable swap for a m715 engine is a "stock" small block chevy. mating a jeep 360 to a t98 is going to take alot of engineering and its has to be extreamly precise or it will kill clutches, and eventually your engine because of miss alignment. runout is .005 to .012 max.
bob
fallen
Meclenburg county nc
Thanks I was trying to decide if I needed to get the engine out of the Jeep Ambulance, the ambulance body is shot with rust. I had a M715 but was very disappointed with it when i drove it, NO POWER. Can you advise what i would need to do for the small block chevy swap as far as engine mount and transmission thanks
msgjd
4,065
upstate ny
30 to 40 years ago, local FD's were installing chev 350's w/chev trannies/xfers in their M715'sthat were convert3ed to tanker/brush trucks and hose reel trucks. Regardless of which engine you go to, the mounts will have to be changed. The 350's have more than enough power if you keep the M715 axles
