Engine Trouble - Blue smoke, rough idle, now won't start
rtbcoop
Tyndall AFB, FL
As a little background, I bought a M1008 from Northside Trucks & Equipment down in Orlando. It was a little on the pricy side and not the best shape but I was kind of in a bind and needed a vehicle. Though I have already had multiple problems with this truck (and I only bought it 2 days ago), the one that I cannot figure out is why the engine is running so rough. I noticed that on a cold start, the motor has a hard time cranking up and once it does, it billows blue smoke for a few minutes. It also has a very rough idle. While driving, the blue smoke continues but is less noticeable. Today, I could not get it to start at all. I believe it is a fuel problem because when I poured some diesel down the air intake, the engine started right up. I also checked my glow plugs and they started right up. I wanted to check for fuel flow so I cracked the bleeder valve on the fuel filter and diesel came shooting out (good pressure). This makes me think that I need a new injector pump but I wanted to check with the experts before I coughed up the money. Any other tests I should do first? Thanks for the help!!!
whatadeuce
Loxahatchee, Florida
As for the injector pump capacity, I wonder if the discharge fuel pressure from the injector pump outlet to the injectors can be measured and compared to the performance standard in the manual? Does the TM for your engine provide a test for this pump? Thats where I would start.
Warthog
229
OKC, OK
Please do not use the "need help" in your title unless you are broke down somewhere.
On this site, when a member reads "Help", they go into rescue mode.
Warthog
229
OKC, OK
Have you downloaded the Tech Manuals and stepped thru the troubleshooting section for "no start"?
You say you checked the GPs. How did you do that? Multimeter and checked voltage and resistance?
rtbcoop
Tyndall AFB, FL
I was broke down, but that's because my starter also died :) Had to get a tow truck to bring me home. Will do though. Checked voltage, it's good. Took out glow plugs and tested on battery, all heated up.
wheelspinner
1,518
North Carolina - FINALLY !
Just because they heat up on a bench doesn't mean the truck is sending power properly to them. You need to go through the troubleshooting steps to determine your issue. Unfortunately when there are many things that can cause a problem, until you step through each one from the most likely to the least likely, its impossible for anyone to do more than guess.
rtbcoop
Tyndall AFB, FL
There are 12v going to the glow plugs when the ignition is turned and none of the glow plugs are burned out. I think I may have found a problem but not sure. I removed the top of the injector pump and there are two solenoids underneath. The larger solenoid (I believe the shutoff solenoid) functions as it should but nothing happens to the smaller solenoid (cold advance?) when I run 12v to it. Would this cause my problem?
