Thank u very muchView attachment 847456
Yes. Just punch the freeze plug in on one side, it should turn sideways then you can pull it out.
Had no idea ,how does that attach if u don't mind. Thanksyou might want to note that your oil pan is probally already set up for a aftermarket oil immersion heater.
Drain oil. Pull plug- side pan on drivers side. Install 120 volt heater in place of plug. I think mine was "KATS" or some such. Secure jumper wire neatly and plug in as reqd. Unplug pre start up to save heater. Fleat trucks and busses may wire in a kill switch to watch oil press or some such, but expense not needed with competent owner-operater. Mine was affortable and works well. "Hard Core" types can use with a coolant heater. Anyway, warm oil always best and Cummings seams to condone the elements! Good luck. Will crank better under 20 deg. Happy batteries too.Had no idea ,how does that attach if u don't mind. Thanks
Thank u very much,very helpfully!Drain oil. Pull plug- side pan on drivers side. Install 120 volt heater in place of plug. I think mine was "KATS" or some such. Secure jumper wire neatly and plug in as reqd. Unplug pre start up to save heater. Fleat trucks and busses may wire in a kill switch to watch oil press or some such, but expense not needed with competent owner-operater. Mine was affortable and works well. "Hard Core" types can use with a coolant heater. Anyway, warm oil always best and Cummings seams to condone the elements! Good luck. Will crank better under 20 deg. Happy batteries too.
