Basically yes but for the later PCS TCMs which do not use a PROM.
Some are EPROMS and some are PROMS, the difference is the EPROMS can be erased using UV and re-programmed and a PROM is a one time use device, no difference to the end user.
I have some of the hex files and can erase and program them, I would like to build a library of the different files, then if I got really bored I could dig into the hex files and decipher the differences and even come up with custom shift points/DTCs etc.
The "major" differences are the NA and turbo chips and likely has more to do with the gearing than the weight, they may have also added or dropped what DTC codes would and would not light the trans light and possibly what actual perimeters set DTC codes and fixed any bugs as time went by.
