Ether- Why is it ok to use on 5 Tons but not CUCV
1,191
Direct injection, vs indirect injection.
Electrically controlled preheater(glow plugs) in a cucv. This is like spraying into an ignition source.
479
Madison, WI
Glow plugs heat up to close to 1500°F ether's ignition point is about 300°F. The ether will ignite explosively and uncontrollably when it hits the glow plugs.
On the IDI 6.2- All the glow plugs are hot at the same time, but the cylinders are all on different stages of their cycle. So you can get the ether exploding and pushing against the piston while it's trying to come up on the compression or exhaust stroke
On a direct injection diesel- the ether mixes with the diesel fuel when it's sprayed into the cylinder, and helps it to burn, only doing so when the piston is on the power stroke.
1,191
The heads, most likely not.
The intake manifold, very possible.
trooper632
Utopia, TX
Thanks, I know its not good to use it on the CUCC's, but I have before as a last resort to start one. I let the glow plugs warm up the cylinder first and only interduced the either after the glow plugs end the heat cycle, but it always sounds terrible. I was just wondering why and know I know Thanks to all
