EUC for pickup
ARYankee
33
Benton, AR
No.... It goes payment... Submit EUC.....Wait for approval.... Wait some more.... then hopefully everything is approved and you get the paid in full so you can schedule a pick up.
jimm1009
71
Louisville, KY
As soon as you get your "winning notification e-mail" complete your EUC
and get it in to G.L.
When you are cleared by Battle Creek then you will receive a letter in the mail if this is your first EUC purchase.
The letter does not say anything about being approved but if you did not pass the muster you would not receive a letter.
Then you will receive your Paid Invoice in the e-mail.
When you receive it then you have 14 days to schedule your pickup (rescue mission).
NOTE: The EUC completion is very very important and must be done exactly right or you will be asked for corrections and this puts you back to the bottom of the pile. Make sure that your ID is color and crystal clear.
Good luck
jimm1009
maplehillfrm
binghamton ny
generally I would say yes,, but it is up to the GL operator, technically you have the 14 days to get them out of there , but the guy.[gal] could complain a bit,, " paper work si supposed to stay with each pU,,etc.....] I think a box of donuts may go a long way,, and a please, thank you,, hey its always worked for me, good luck with your pu, :driver:
stampy
22
Henderson. NC
If you have to get a title ie:for a deuce or other truck then you need a sr97 which you can't file for till the vehicle is removed from the base ( I know it's:cookoo: but thats the way they do it)
wreckerman893
Possum Connoisseur
15,628
2,047
Most GL locations will work with you on pickups if you have a decent attitude.
A lot depends on how much stuff they move through a particular site and how much help they have.
A lot of active duty military bases require you to be escorted to the GL location if you dont have a military ID (retiree ID is OK). This means someone from GL has to meet you at the gate, escort you to their yard, and escort you off the base. This takes a lot of time and manpower.
If you miss an appointment you will not endear yourself to them and they will remember it.
Another problem is "Unmanned sites".......the GL rep often has to drive a long way to open the gate and help you (and other customers) get your stuff. Some of these sites are only open one or two days a week if that. They try to arrange several pickups on the same day but you are on their schedule....they won't adapt to please you. Most of the time in this situation they will not be too strict on the 14 day pickup deadline.
And as mentioned above a box of donuts will be remembered after you are gone.
