Existing Slide adapter for new brake adapter, P/N 10453002 (Allows removal of Differential Cover)
azulrios
13
Incline Village, NV
Has anyone changed out the brake Adapter for the new brake adapters, P/N 10453002?
I was unable to locate a TM for this activity. Any guidance welcomed.
I am in it so deep now, not sure how to get out of the swamp!!
azulrios
13
Incline Village, NV
Thanks.
If I understand correctly, the 10453002 is OK for the changeout on the A0 / A1 HMMWV. I have a M1025 (Code H17).
I sure hope so. Stripping down to remove the differential cover is a real pain.
Regards,
Retiredwarhorses
4,603
Brentwood, Calif
Thanks.
Regards,
Be aware the fronts are 2 different part numbers, the rear are the same, so for an entire truck, you would need 3 of one part number and 1 of another.
Also, it’s not required to remove the yokes to remove the diff cover.
