.Has anyone extended their axle vents to a higher location? If so, where did you extend them to? I am thinking of doing this to keep water out of axle. Any thoughts on this?
Sorry, that’s pre filter on the m939 series, I just realized you’re probably working on an older truck that wont have these. Do not plumb it in after the air filter as you will be pulling positive pressure on your vents.I never noticed ports on the air cleaner. I will look when I get home. Has it helped keeping water out of the axles?
.Can someone enlighten me as to the purpose of the vent/valve for axles. Is this a popoff that is used with a tee for the air pressuring hose or does the hose attach to the axle elsewhere?
i am also going to enquire about the effectiveness of the fording / vented fuel cap. It looks like there is a valve you turn on the underside to change it from vented to sealed?
View attachment 938283View attachment 938284
