- 820
- 858
- 93
- W.WA
I'm doing some work on the battery box and figured now's a good time to change the battery cables. I'm upgrading them to a thicker cable, y'know, because I can.
On the passenger side, corner of the cab is an external power plug. I'm wondering if I should cut this out of the system.
I've pulled the plug free and I don't see a good way it comes apart. I'm moving to a thicker gauge of wire and don't even know if the plug will support this.
Realistically, I don't see that this plug will get much (any?) use even if I keep it hooked up. Is there another option, maybe an aftermarket solution? I don't mind the idea of supplying external power for something, but how many 24v applications am I likely to run into these days anyways?
What have others done that have come to this?
