extra loud ping/detonation
jag7720
Kansas City, MO
I posted this on diesel place too...
1985 M1009 6.2 25,000 miles
This is going to be hard to explain.
I have been noticing an extra loud ping in my engine. It only happens under load.
When I am cruising at 30 or 40 mph or highway speeds. If I lift off the accelerator it goes away... If I give it full throttle it seems to lighten up.
It is does not have any rhythm and it "sounds" like is is a single extra ping.
It does not go away when the engine is up to temp.
I want to say the it almost sounds like the loud pings you get on a cold morning and the engine is on high idle while you are driving.
Anyone have any idea what might be going on and what I can do to make it stop?
1,176
bad injector?
lavarok
33
Fellsmere, FL
Bad fuel? I recently had a problem with some bad diesel from a small station off the interstate. I thought my engine was getting ready to fall apart. Luckily, it was only 3 gallons. I put some fresh off road in once I got home and within 10 minutes of driving she sounded purty again.
jimm1009
70
Louisville, KY
extra loud ping.
I have heard of th low sulfer fuel doing this but I am no diesel expert.
You might consider a fuel additive to improve lubricity of the fuel.
Also check the "rough timing" of the injection pump.
The top of the engine has a timing mark and so does the pump.
The lines should be lined up together if everything is good.
It's easy to do. Just pull the air filter assembly and take a quick look.
Jim
1,176
Opening to soon or sticking. Get them cleaned/tested or replace them with new or rebuilts.
