Fan clutches
kapnklug
spencer,ny
Ya that's how they're supposed to feel, can turn by hand but not spin freely. I've only seen them go bad by losing all resistance so that the engine overheats
kassim503
Stony Brook, NY
Sometimes the thermostat on it gets stuck and they stay locked all the time. Try starting the truck when its cold and holding a high rev for 30 or so seconds, if during that time the fan dosent slow down or making that loud whoosing noise your fan clutch may be bad.
Also, if you do decide on replacing your clutch, make sure you get the one that looks like yours, there is usually a hd one and a regular duty one. The regular duty one spins the fan slower, while the HD one may lock up too much for your liking.
rlwm211
Guilford, NY
In my experience when a thermal clutch fan fails the fan stops engaging and properly cooling the truck. The test is to check the fan with the truck at temperature, but not overheated. With the engine off, spin the fan with your hand and it should stop in less than a revolution. Also check for wobble and any other indication of bearing failure. If the fan bearing fails it can take out your radiator and that can be an expensive proposition.
It is absolutely normal for the fan to run on "HIGH" for a minuite or so when you start out with a cold engine. Typically my fan stays at high until I start driving and the first acceleration it slows down.
RL
