fan switch wiring
choll
Las Vegas,NV
Im having an issue with my fan on/off speed control. The blower works. When I had the dash pad off for replacement I thought I had it fixed. Well it stopped working today. Does any one know of a quick by pass so I can get air blowing to clear my windshield. When I had the pad off I thought about pulling the full control unit but that was way out of my skill set. I dont mind pulling the dash pad if its going to be the last time. I dont mind if the blower is wired in the high mode or low mode.
blackhueys
-9
mn
best fastest way for me at least is to just jump from the front battery (12volts!!!) straight to the fan. Of course this is a temp fix as it will run all the time but it will get ya home. I had this happen to me last winter, since then I have made up a 4 foot long wire with a alligator clip on one end for the battery and the other end has a quick connecter to go on to the blower motor.
