- 215
- 80
- 28
- Rushville, IN
My fan quit working some time ago on my M998 but I'm just now getting around to troubleshoot it. Previously, it started cycling on and off quickly one or two times, then would stay on to cool. But it would come on early, somewhere around 190-195 so it was running pretty much constantly once that temp was reached. Now it doesn't come on at all unless I unplug the time delay.
I've gone through the diagnostic flowchart down to this page. I'm assuming by "voltage", they mean 24v? If that is the case, it leads me to the transmission. However, it just sends me to the general section of troubleshooting the transmission.
For additional info, I'm in the process of swapping the 6.2 to a 6.5TD which is done and also the trans to a 4L80E which I'm waiting on. This was an issue before I started the swap though so I don't think it's related. I did not change my body harness as I'm going to use a stand alone controller for the trans and I'm using my original engine harness on the 6.5TD. So I do have the two plugs for the kickdown that are not connected to anything at the moment. Like I said before, this was an issue prior to the swap so I don't think it has anything to do with my issue now. But, I wanted to ask the experts.
Any thoughts on additional tests I can do or is there a likely component causing my issue?
