FDC leak
cranetruck
94
Meadows of Dan, Virginia
Checked two different fuel density compensators on the bench this morning. One leaks and one does not.
The leak occurs around the piston rod, which has no gasket but is only a metal to metal fit.
Apparently the leak is caused by wear, although the there is very little movement while in operation. The piston moves from one extreme at start and moves to a new position depending on the fuel viscosity. There is also some movement as the viscosity changes with increase of fuel temperature.
I used compressed air at about 20 psi and with the FDC turned upside down there were bubbles in the oil around the piston rod indicating a leak..
My FDC started leaking after about 1,400 engine hours and the rate was about 1 quart/25 hrs.
In my case, microscopic rust particles could have been a contributing factor and I'm now looking for some kind of magnetic device to add to the filtering system....suggestions would be appreciated.
If any of you have experienced a leaking FDC, how many engine hours did you show?
Floridianson
2,538
Interlachen Fl.
Saw someone had taken a old speaker magnet and placed it on the bottom of there oil pan. Could something like this be applied to the fuel canisters?
