Fender mounted warning lights.
814
Universal City, TX
Do the fender mounted amber warning lights on the older 5 ton wreckers flash, or do anything other than stay solid? I am looking to add a couple to my deuce. (for some reason I am not happy with a stock truck and have to constantly add things to it). And does anybody know where I can get a couple light assemblies w/the bracket that attaches to the fender. ( I am aslo looking for a 24V siren for parades and such. Thank guys.
Tlauden
Halifax Pennsylvania
If they are a solid burning light you could probably modify a turn signal flashed to flash them light if you would want to do so... Although for the $ u would wrap up in them I would go with modern LED strobe light heads... $30 a piece and has tons of flash patterns. But then your into the 12 volt on a 24 volt system... But whatever you wanna do go for it!
Something along this line. I got a variation of these (blue in color) on my f150 and they work great day and night for moving traffic! Real easy hook up too
http://www.ledoutfitters.com/index.php?target=products&product_id=52
jasonjc
288
Gravette Ar.
It was only on the drivers side. You maybe thinking of the trun signals that were added to alot of the trucks in eroupe. They had a side clance light and rear faceing trun signal. Some had the trun signal that was seen both front and rear also.
