Ferret radiator hose replacement
L1A1
13
H'burg, VA
Anyone on here ever replace the hoses on their ferret scout car? 'been researching how to do it and my question for those that know & have is this: The rubber hoses used appear to be just straight 'coupling" types w/no bends or odd angles moulded in. Can generic radiator hose* cut to fit be used?
Matt
* What I mean is actual radiator hose-not generic black rubber hose.
dmetalmiki
2,028
London England
ANY good quality reinforced hose (the type with banding through the middle that looks like string threads) Will do it. We have used 'other' (strong) Hose for the 432, and quite a few of our deuces and 5tons over the years. Even hoses that have bends in them can be found that will readily form to fit most tasks. Post up your remedy and ongoing fix with pictures.
L1A1
13
H'burg, VA
Ok guys thought I'd pay it forward a little for anyone in the future who may be undertaking the same tasks as me (belt & hose replacement on a ferret scout car).
You can use your old hoses for measuring the proper length when you cut the new ones down. All parts came from carquest auto parts
radiator hose(s) are 1.25" dia Dayco part# 76125
water pump hose is 1" dia Vulco part# 24016
radiator overflow drain hose is .25" dia Carb part# 0-09-019A (J30r14T1)
Oil sump hose is 1" dia ThermoId Hercules II part# MSHA 1C-114/1
If your ferret has the Alternator & not the generator, then it takes an automotive type belt- 3 of them. The belts I found (again, at carquest) are 1/2" X 53-7/16" (13mm X 1357mm) part# 9530HD
Hope this helps.
Matt
