tucker79
- 0
- 16
- S FL. United States
Dragged this truck out of a field, checked all fluids, bleed brakes aired up tires and a good push start with the loader and fired rite up and away we go 2 hr drive home. So much smoother & a little faster than my 818 even with the 11.00s.
Just about got the 818 NHC figured out and now Im hoping you guys can suggest some threads TM references on the multi fuel.
Q1 What is it??? 5 ton multi fuel is all i know dash is stripped of all data plates??
Q2 Lots of in & out play on dual piston air compressor pulley shaft any rebuild threads??
Not getting air assist at air pack
Q3 Seal leaking at power steering box shaft can I replace that seal without tearing all apart?? threads TMs??
Q4 Output seals on trans and TC Can these be replaced without removing trans/TC Threads??
Q5 What is the small square head plug on top right of air compressor (Oil??)
Q6 Is there a wider tire I can put on the front that will match 11.00s on rear
THE GOOD Lots of new parts MC, tie rod, air pack, 12V starter/alternator lots of newer seals Almost no rust, I think whisler turbo sings a sweet song
The BAD Fire department left a pile of spaghetti for me to remove, No lights, injector line leaking a little, syncro shot 3rd gear All in all Im happy with it and this being my 2nd 5 ton I got a lot of little stuff figured out with out bugging you guys with Qs but still a newbie Any help appreciated
THANKS GUYS
