DeuceNewb
- 6
- 18
- Wilmington, NC
I just purchased a 5ton with a flat tire. I've never had a 5ton, or a deuce, with singles on it before. in the first picture you will see the flat tire.
My question is : is that tire fully flat or still holding some air? I would think that if it were at 0, then the rim would be on the ground. Maybe i'm wrong though, because I bet the sidewall is pretty strong on those.
second, assuming that it's flat, I could probably replace the tube and be good to go. The rear rims should match the front rim (pic 2) right, and from looking at it, can I take it apart with those outer bolts and change the tube myself or will I need special big tire tools?
