fifth wheel assembly informations
Guyfang
23,926
Burgkunstadt, Germany
There is no such thing as a manufacturer manual. There are Army TM's. What info do you want? Do you want the parts book? Or repair info? If so, Go to the top of this page, where it says Technical Manuals. Click on it. Next look for 5 Ton and Up TM's. Click on it. There are two pages of TM's listed. Go to the second page. The third thread from the top, TM's for the M39 Series 5-Ton Truck is the right thread. Click on it. There are lots of manuals there, so tell us what info you need.
hkesse
hello,thank you for quick response.
the only thing i am looking for who is the manufactior of the fith wheel assembly.
best regarts kesse
Scrounger
66
Southern, Maryland
I’m pretty sure that the fifth wheel on the M52 was made by Holland. They may not be marked as such, however it is a Holland design. The same fifth wheel was also used on the 800 series tractors and on the M197 and M198 dollies.
Guyfang
23,926
This is interesting. The Cage code for the 5th wheel is 19207. Tank and Automotive Command. That tells me, the 5th wheel was procured from several different manufactures. Scrounger, if you say Holland made it, then I guess that was one of the suppliers. But there were more.
The TM's are very old, poor quality reproduced. The picture of the 5th wheel is on PDF reader page 551. Its figure 120, and the entire 5th wheel is Item number 1. Part number 11640352, NSN 2510-00-809-7791. The write up for the 5th wheel is on PDF page 188.
73m819
323
gainesville, ga.
There were two makers of the m52 fifth wheel,
International Harvester Co, Inc. (IHC)
Dayton Steel Foundry Co. (DSF)
There WILL be a embossed id (one of the two (xxx)) somewhere on most of the big parts, the fifth wheels are the same with the parts interchanging,
ALL the above info. is from g-744 ORD-9 (744 series parts (-9) tm for the 39 series Ao before it was the 39 series ) part of the tms BEFORE the MODERN TMs
NDT
6,486
Camp Wood/LC, TX
I agree with this. Holland did not make the original fifth wheel on these trucks. Dayton Steel Foundry did. Holland made the fifth when that was used to replace the original starting in the 80's.
