Fill Jet A1 into the humvee?
HUNvee
242
Hungary
Can I put jet fuel in the humvee? Should I mix it with diesel or add some extra lubricant?
Does anyone have experience?
Mogman
8,984
Papalote, TX
I would use a lubricant, also there is a 5% power loss and a 5% loss in fuel economy using the Kerosene based fuel.
There also seems to be a larger number of defective IPs in the surplus military vehicles using JP8
Tow4
640
Orlando, FL
You do need to add a lubricant. When I was running Jet A in my 7.3 Power Stroke, I put 5 gallons of WVO with 25 gallons of Jet A. Realistically, you probably only need a gallon of VO. I've bought a gallon of Wesson VO at Publix and poured that in when I didn't have any WVO on hand.
Mogman
8,984
Papalote, TX
Southwest Research Institute studied the use of JP fuels in the DB2 pumps. There is ZERO issue with lubricity.
First they only tested 5 pumps and had no operational history on the pumps, second they confirmed that JP8 is a "low lubricity" fuel, of the 5 pumps they could not determine why two of them failed but felt that SHORT-TERM operation on low lubricity fuels was not the cause.
I am positive if I had to run on JP8 I would use a lubricity additive, just as I do on ultra low sulfur diesel.
You also have to consider the military saves a butt load of money not having to invest in the logistics of shipping, storing and distributing more than one type of fuel so they could justify the costs of replacing fuel system components on some of the motorized fleet.
So to say they found ZERO issue with low lubricity would be incorrect, also one usually finds the results wanted by the folks paying for the study or in the future they go pay someone else.
BTW I worked for SRI in San Antonio when I was young in the "Cat Lab" where we tested engine lubricants on single cylinder Caterpillar engines, VERY hot and so noisy we had to use two types of hearing protection and were tested every month.
For every argument one can find an opposing opinion
EDIT there is no argument that the fuel lubricates the Roosamaster IP, so the term "low lubricity fuel" is all I really need to know.
Guyfang
23,157
Burgkunstadt, Germany
10-15 years after this study was done, the CECOM mandated that all units using JP8 in gen sets, were to add oil to the fuel tank. I can not produce a document, as its been too long ago, and I tossed out all that stuff in 2010. But I saw and read the directive.
HUNvee
242
Hungary
As far as I know, the JP8 contains lubricant, which the A1 does not. In Saudi Arabia, when A1 was refueled, there were failures in the injection pumps.
Guyfang
23,157
One night at 03:00 Berlin time, during the first sand box war, I called THE senior Air Force Fuels NCO in Iceland. I asked him what the difference was, between JP-8 and Jet-A1 was. After he explained to me at least 45 min, everything there was to know about Kerosene type fuels. What I learned was that Jet-A1 had an additive to keep water from freezing at extremely high altitudes. Nothing more. I had received a phone call from C-1/7 ADA, Patriot. The unit was 10 klicks from Basra, and had 1 hours fuel left. The only available fuel was Jet-A1 from the Air Force. "Can I use it!!" My answer then, was "Yes, go for it." This is the list of Authorized Fuels, taken from the -10 TM.
FUEL REQUIREMENTS — TEMPERATURE LIMITS (VV-F-800)
Grade DF2 Fuel . . . . . . . . . . . . . . . .For use above +10°F (-12°C)*
Grade DF1** . . . . . . . . . . . . . . . . . .For use below +10°F (-12°C)
to above -20°F (-29°C)
Grade DFA . . . . . . . . . . . . . . . . . . . .For use below -20°F (-29°C)
All Temperature Alternate . . . . . . . .JP8
* Temperature limits may vary dependent on the cloud point of the
actual DF2 fuel being supplied in the geographical area.
** DF1 is not normally procured in CONUS or OCONUS. Refineries will
blend DF2 with kerosene to meet temperature requirements of DF1.
87cr250r
1,973
Rodeo, Ca
However, preliminary tests and calculations reported in Reference 1 indicated that pump seizure was not primarily due to the decreased viscosity of the aviation fuels. As a result, the test series was designed to highlight the effects of oxidative/corrosive wear.
The SAE intro makes the same statement. Fuel viscosity/lubricity were not contributing factors to pump failure. The recommendation was to test for oxidation and corrosion from the fuel. This is usually evaluated with the copper strip test (ASTM D130).
ToddJK
4,515
Sparta, MI
Imo, when using jet fuel, just adding some wmo is sufficient depending on your engine. That's what I did when I had a few hundred gallons of it, I ran about 10-15 gallons of wmo to 35-40 gallons of jet fuel and my deuce ran great. It also seemed to have way more power and better fuel efficiency with the jet fuel over diesel and especially over wmo alone. Running it alone though, I don't know about that, it was clear and any that got my skin seemed to dry it out real bad like gasoline does but unlike gasoline, this stuff kinda burned too. I don't see why new or clean oil won't suffice in other diesel engines if mixing with jet fuel.
Coug
4,239
Olympia/WA
personally I like Optilube XL.
back in 2007 someone did a study for different additives and their effects on lubricity.
It's about as unbiased as a test as you can get, and most of the additives tested are still readily available today.
The Optilube XL wasn't on the list because it wasn't out yet, but it's apparently better than the XPD version and requires less. Doesn't have the anti-gel in it is probably the big difference.
EDIT: basically the best additive at the time was making a 2% biodiesel blend. I have heard though that once you start going above about 5% blend the benefits start to diminish? Can't verify, just something I heard.
