Filling out SF-97 help for n00b?
SixSpeed
Banned
1,107
Tampa, Florida
Hey Guys,
Filling out my first 97, could use a hand. The only things I do know:
1.) I don't want to mess up.
2.) I don't know what I am doing.
Now that that is taken care of, here is what I need help on:
Year: Really Don't Know
Make: Kaiser-Jeep (Says on dash)
Model: M109A3 (That one was easy!)
VIN#: ????
Body Style: Shop Van? Truck?
Color: Its camo?
Weight: That NSN Report says "15030"
GVWR: That NSN Report says "15030"
The more I poked around on GL, the more confused I got with the information. I clicked on the NSN number under the Item Manifest for an "NSN Report", and I am not really sure what I am looking at. Has a TON of information, unfortunately it might as well be in Chinese. Said AM General in a few places...something about 1985 order...also said something about a fording kit and some other stuff I don't have. So I don't know what to believe on it....
Any help is GREATLY appreciated! :)
rwonsala
MANASQUAN, NJ
Year: Check the tag on the dash for the contact year, close approximate.
VIN#: This is stamped on the Kaiser-Jeep metal plate, check there
Body Style: Truck
Color: Green
Weight: 15500
GVWR: 23000
:grd:
phil2968
Lakeland, Florida
Have carnac run all the numbers you have in the 2010 vin info thread. Vin number is on the left front outside of the frame rail under all that paint. mine is also stamed in the rear cross member near the pintle hook. Carnac told me exactly how many miles were on my truck when I picked it up. Can you read the bumber numbers?
jimm1009
71
Louisville, KY
I sent you a PM and email but you can also find the s/n and possibly the heat treat date of the frame on the left front of the frame in one or two areas. Area #1 is just to the rear of the steering gearbox mounting area and the other is just in front opf the top shock mount.
If you can, use a putty knifre to loosen up the top layers of sludge and then use paint stripper to remove the paint down to the bare metal.
Don't sand too much or you can damage the numbers in the frame.
As mentioned above, post the information on the serial number and registration number here and the others can help.
jimm1009
SixSpeed
Banned
1,107
Tampa, Florida
CARNAC couldn't find my truck with the information given. I looked on the chassis for a #, but I couldn't even see a hint of a # so I guess I need to do some sanding.
Any suggestions for filling out the 97?
Heres what I posted in CARNAC's VIN thread:
Kaiser Jeep (According to Dash Plate) M109A3 w/ow
a. Serial Number (VIN number) - 033210628
b. Registration Number - None
c. NSN - [FONT=Verdana,Arial,Helvetica][SIZE=-1]2320000771636[/SIZE][/FONT]
d. Bought From GL - Redstone Arsenal
e. Bumper #'s Had Been Removed
