filter change on the deuce
kipman
15
Lancaster Ohio
My truck was hard to start and would idle very poorly so final got around to a filter change. could not believe what came out of the primary filter,runs way better now.
emmado22
143
Mid Hudson Valley NY
Check the secondaries also, that can only help the situation. If you got alot of gunk out of the primary, check the 2 others!
acetomatoco
What is the long filter on the left, certainly not a M/F deuce primary....which is a short paper filter, albeit metal wrapped in some iterations.????
1,124
I believe that on another filter thread here, that some folks had found this long filter in their primary canister direct from the gummint. Obviously the spring and assorted hardware that keeps the standard shorty filter suspended was MIA....
WillWagner
2,485
Monrovia, Ca.
Ace, That type of filter is cleanable and re useable. It does need the cup and spring to be effective though. I have a short one made of the same material. It's supposed to be white!
Bill W
44
Brooks,Ga
Thats a micro-bond filter element
My M-37 and my M-38 had this type filter element mounted on the pickup tube in the fuel tank. They were also in other M-series. It has a 30-40 micron rating and resistant to passing water, they don't have much of filter surface area so they clog quicker than pleated paper elements BUT ( as mentioned) they are cleanable. I pulled mine out of the (37) tank and put a spinon filter under the bed.
acetomatoco
Yup, had never seen one in use before... leaves no room in the bottom for water and trash to collect...had seen them in use intank though...in various rigs...wonder how they seal the bottom
WillWagner
2,485
Monrovia, Ca.
They seal the same as the ones with the cork gaskets, with the little cone at the bottom. When I got my 1st set of filters, the primary was the white, re usable one. I thought it was incorrect, so Im called Norm...AVTE..and he took the time to splain me 'bout it. Then I saw a post from cranetruck about them. I can't post pics now...guess it takes a few days to rid my account of stuff. I'll post a pic of the short filter when i'm able to.
