finally turning in SF 97's need help with vin # on M818's
377
Owatonna, MN
Hello,
We would like to submit the SF-97 forms on the two M818 tractors we purchased from Stout Field. This is our first SF-97 experience and are looking forward to the long wait!
Truck #1
Fed Stk# 2320-00-050-8984
id#C124-10562
Truck #2
Fed Stk#2320-00-050-8984
id#C124-10462
I'm assuming the fed stk# is the vin that I need to put on the SF97?
Also what year is truck 1 and 2 built in? The SF97 asks for weight and the data plate shows 19,500lbs which seems excessive for a non winch truck. Should I still list it as 19,500lbs?
Any help with the above vin#'s would be appreciated.
Thanks,
Andy
1,807
RE: finally turning in SF 97
Don't use the FSN as the VIN. Check it out, they are both the same. The C124-xxxxx number is the VIN. The weight sounds about right but I can't help with the year (poorly versed in 5 tons).
CGarbee
548
Raleigh, NC
If you post the contract number in addition to what you have already posted, sombody (like DDoyle) will be able to tell you the year. What manufacturer name is on the dataplate?
Good luck.
DDoyle
80
West Tennessee
They are both 1970 Kaiser-Jeep built trucks. As stated above, the VIN is the C124-XXXXX numbers.
Best wishes,
David Doyle
