OkieM1008morrison
- 3
- 0
- Skiatook, oklahoma
so I finally managed to finagle and horse trade to get my first 900 series 5 ton, this is uncharted waters for me, the cummins is also new to me. the truck came from a rural fire department that accessed the truck from the forestry department. long story short I am the new proud owner, it is a low mile truck at 1250 miles and is painted ugly red. formerly desert tan and a quick paint job at that. so last week I went and picked up the truck, had to be slave cable jumped because the 4 hawker battery's were completely dead. the truck was 'idling' when I got there, it would rev up to about 1100 rpms and then go down to 400 rpms and almost die then back to 1100...the cycle went on and on. I get in to drive it the 40 mile trip home and push the pedal..it does nothing and then 4 seconds later it picks up and im driving away. feels as if it has no power on the way homeruns 50-55 the whole way home. but real laggy...and lethargic. on arrival I let the truck sit and idle, I went ahead and filled both tanks to the top with new diesel. its still idling exactly the same as it did before after about 30 minutes of idling like that it died and would not start. I managed to track down a small leak on the tank selector valve and ended up replacing 2 rubber lines because they were stamped 1988. also I replaced the filter and put in new o rings on the filter housing bolt and underneath the rim. filled it with fuel and pumped the primer and it fired up within 2 seconds and ran great for 2 minutes, idled at a smooth 600 rpms and then died, wouldn't start after that. I pulled the filter and it was only 1/8 full. so I took my air chuck and blew backwards through the lines to see if I had a blockage, but everything was free flowing. I filled the filter back up and pumped the primer and it started and ran again for another 2 minutes at the smooth 600 rpms. then idled up to 800 rpms and died...
what could I do to figure out my problem? how do I tell if the IP is going out? it draws the fuel correct?![5 ton 1.jpg 5 ton 1.jpg](https://www.steelsoldiers.com/data/attachments/369/369258-fbb92b03087112b6ceca6390f6c26c73.jpg)
![5 ton 2.jpg 5 ton 2.jpg](https://www.steelsoldiers.com/data/attachments/369/369257-2a3c6d6cbd7c6bc895cd9b9d5bbb20ba.jpg)
![5 ton.jpg 5 ton.jpg](https://www.steelsoldiers.com/data/attachments/369/369256-14aee58e880c0455fa3efb431d8ba205.jpg)
