Fitting size?
DaneGer21
1,162
Creston, Ohio
Does anyone know off the top of their head what size and pitch, or what the fitting is that’s on the fuel outlet on top of the tank? It’s a flare fitting originally, but I’m at work and can’t actually size the female side. I’d like to find a fitting to screw into it other than the original flare. I’d like to convert right to my DOT plastic lines, versus a compression/compression conversion from a small copper section to plastic.
Hope that makes sense.
I’ll attach a screenshot of an old picture of mine…circled in red…
DaneGer21
1,162
Creston, Ohio
Sorry I must be misunderstanding, I want to remove the original fitting and copper all together. Then replace with a fitting that adapts from that 1/2” thread to 1/2” compression so I can connect my brand new plastic lines
I appreciate the info, I’ll hunt down what I need from there
1,178
Look up the part number in the parts technical manual. Then look it up on Parttarget, for all the specifications.
