Fitting the M35 cargo cover on the M135
dabtl
Denton, Texas
The side posts on the front and rear need to be 42 inches in length. The middle posts need to be shorter than that by several inches.
I put an early green vinyl top on at those measurements and it fits fine.
acetomatoco
that is because, of course that the M135 used a M34 Body...and the M211 used the M35 Cargo body...by golly... ACE
dabtl
Denton, Texas
Agreed, but the length of the side boards is not found so easily. It just makes anyone reading the post more informed quickly. They will not be cutting and fitting nearly as much as I.
acetomatoco
The height of the bow is the answer..you want em all the same...The support length then becomes the solution...ACE
