Fixed! Carnac is broke down!! Needs help!!!
atankersdad
15
Glen Arm Maryland
Just got off the phone with Carnac. He is broke down on highway 66, in Va at exit #13. This leaves him 13 miles west of I-81. He has broken off the RF lugs and will need new lugs, nuts, a large hub socket, and anything thing else you can think of. If you are in the area or can assist please call. I will be in contact with him as needed. I called and left a message at the home of a local member to see if he can help..
Jakob
Louisville, KY
While I can't help, this may spark something that COULD help someone in the future. What about a list of names, locations and phone #'s of people willing to offer their services should someone be broken down? On an Oldsmobile website I used to be a part of, they maintained a similar list.
319
Lieutenant
57
Michigan
What is the underlying issue? Flat tire, wheel bearing?
I have the 3" axle nut socket, special keyed washer, one bearing locknut, and three lug nuts I can overnight. Need to let me know before 2PM EST.
I'll PM you my cell ph#
1,127
Is there someone with a FWTD or a wrecker who can get him to a point where the studs can be replaced? Stud replacement isn't difficult on one of these.
1,806
I'm checking the map, where is hwy 66? Sounds like he might be close to Cranetrucks place. Pls advise.
maddawg308
745
Front Royal, VA
He's right by me - I might be able to help get him some parts, researching that now, but I cannot tow him anywhere with the front like that. Will advise....
atankersdad
15
Glen Arm Maryland
I just spoke with Carnac. Daniel is on his way to help him. Daniel has a complete hub for him. This is a great site in times of need. I will kep you updated.
hdexpert
Worthington Ohio
In the case of oilcan, a leaky seal, lots of offroading= muddy looking grease which caused complete inner wheel bearing failure and the tire blowing at highway speeds!!! I was driving at the time, big pucker factor!!
badgmc56
Southington Ct.
When wheel studs break off. most of the time it's because the lug nuts got loose. The constant pounding of the wheel against the studs, sheers them off. Check wheel tightness often to prevent this.
CARNAC
The Envelope Please.
617
Corpus Christi, TX
HEY ALL, I am now at my parents house. Truck is fixed.
Thanks to everyone that helped. Mike had already researched the part and was getting ready to head for NAPA when Daniel called and said he was on the way with a complete hub.
Thanks to Clint and Dudley for the commo support by getting me phone numbers for my expanding phone book.
And thanks to everyone for the concern.
Heading out the door for the show.
Take care
CARNAC
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Excellent!!!!!
Another fine example of a "community" pulling together to help out one of it's own. That's something you just don't get in this day and age!
