brakejay
- 4
- 1
- Milford, MI
My ABS light started staying on this Spring. I checked the fuses under dash, fine. When the start swich was flipped I did get the 2 "click-click" system check. I wasn't sure where to go from there. Started crawling around under truck.
I found a broken wire coming from the pass-rear wheel speed sensor. At first, it was hard to see the underside of the harness had been cut on the brake bracket.
Spliced black-black and white-white wires back together. Good to go. No light!
If you have an ABS light, check your wheel speed sensor wires on the rear most axle.
![](http://uploads.tapatalk-cdn.com/20160718/3ff2def301086057352abdfcf32ef437.jpg)
![](http://uploads.tapatalk-cdn.com/20160718/3128f768006bc13b3612c9b745fa13a8.jpg)
