Fixed my leaking HH ...woohoo!
ccf460
granite falls/N.C.
My truck has always had a fuel leak coming from the HH. After several degreasing search missions...I finally saw it leaking around the center bolt on the top of the HH. I took the bolt out , saw there was no copper washer....? Wonder how many trucks are leaking in this area. I found an o ring that fit tight around the bolt shaft. As a side note, the hole is chamfered to make room for the copper washer, so I figured the o ring would fit in there also. After installing the bolt with o ring, the fuel leak is gone. I hope this helps someone else.
Jeepsinker
470
Dry Creek, Louisiana
Mine is leaking from one of the line fittings. Can't get to it with the other lines attached without a crows foot wrench, so I have to remove a couple of lines. Only leaks when it gets hot though.
welldigger
Benton LA
You may need a new injector line. I have 3 leaking. Just received 6 new ones from White Owl.
