Fixing a delaminating ballistic windshield
GMVguy
116
Texas
I have searched the forums and can't find a solution. Cutting the glass isn't really an option on these thinner ballistic windshields (like some are doing on the Ibistek ones).
My 5/8" ballistic glass is delaminating something fierce and I want to either stop it, repair it or replace the components needed. I thought I remember someone had a method to carefully separate, remove/replace the laminate... can't find it. Anyone know of a solution?
juanprado
3,215
Metairie/La (N'awlins)
Action posted this:
I think there are some other threads on this also
GMVguy
116
Texas
Action posted this:
Yes, that thread is about the Ibistek knockouts I mentioned in my original post. The solution there was to cut out the top couple layers to remove the problem. Not possible with the 5/8's I'm dealing with.
GMVguy
116
Texas
Yes, that study gives a good understanding of the problem. Seems to be the thermoplastic polyurethane "TPU" layer that's failing.
Another study referenced a company called The Glass Doctor of St. Petersburg, Florida, who's simple "Patented Technique for Repair of Delaminations in Glass" repairs delaminations by injecting an adhesive between the delaminated plies per Figure 3.1. (W/WS, U.S. Patent # 4,780,162):
Unfortunately I can't find them, so they must've gone out of business. Every company I've tried either doesn't repair delaminating ballistic windows, or charge $1,000+.
Retiredwarhorses
4,626
Brentwood, Calif
All ballistic glass suffers the same fate due to exposure to the element, and it’s all addressed the same, you have to remove the poly layer that’s delaminating from the glass. In the govt world, this glass ultimately has a shelf lift, ive installed a lot of it over the years and seen my fair share already starting to delaminate still in the packaging.
Find the poly side and start slicing with a good razor blade….i have one last set of that 5/8 WS glass, it’s mint.
GMVguy
116
Texas
They’re becoming pretty rare. I think I’ll take it to get delaminated and possibly have another poly layer installed if I can find a shop that can do it.
Retiredwarhorses
4,626
Brentwood, Calif
i seriously doubt you will find a company that will delaminate that glass and apply new…adding any thickness with additional layers will render the OEM seal and WS retainers useless, I’ve done door glass on 5/8 and makes you add something to the edge because the dimensions for the seals and frame are figured in to make a good solid fit.
GMVguy
116
Texas
Makes sense… it would only work if the replacement poly layer is the same thickness as the original.
Will likely end up using laminated/tempered in 5/8” (or 3/4” if it’ll fit with the retainers & seal)
Mogman
10,596
Papalote, TX
I have seen laminated glass and I have seen tempered glass but never laminated tempered glass.
Retiredwarhorses
4,626
Brentwood, Calif
Tempered is not used on WS’s, it’s used in side windows, if it’s on the windscreen? It’s laminaged, and 5/8 glass is expensive, I’ve sourced it…it’s an odd size. if You aren’t installing OEM glass? Than just install standard 3/8 glass, putting in 5/8 safety glass just ends up being a waste of money for looks and no real ballistics, going with OEM affords you some level is balastic protection, not sure what truck your installing it into…but it was never in the ECV GMV.
GMVguy
116
Texas
9/16” laminated/tempered is available, which would be 1/16” smaller than OEM. Think that’ll fit with tolerances for the stock rubber seal and retainers?
radioguy971
Webster ny
could you inject clear epoxy into it?
GMVguy
116
Texas
I believe that's how the big restoration companies do it, but they have equipment to inject and compress the layers under high heat & pressure. If I could find the equipment and materials to do it myself, I would try it.
