Flame Heater delete
FreightTrain
Banned
2,730
13
Gadsden,Al
Does anyone sell just the plugs for junking the flame heater?Mine is now laying in the yard and I rednecked the plugs.3/4" Rubber exando freeze plug thing and blue glued a Pipe Plug in the the spark plug hole(Plug threaded in losely).I also found a plug that would fit the IP fitting.I couldn't get the old one out.Sucker is in there good.I could only get the compression nut off and found a plug that "Fit" and also blue glued it in.But I want to get all the right stuff to do this.I don't want to install a Ether kit since that is just more junk under the hood.I plan on just throwing a can of Thrown Rod in a can in the tool box incase I ever have to use it.I have never use the flame heater on my truck so I "shouldn't" need the spray.....
builder77
I can get you the part numbers for the plugs for Quickstart. They are helpful, so they might be willing to hook you up with just the plugs. I think the actual injector plug is not a pipe thread, but just straight which is kind of weird.
OPCOM
27
Dallas, Texas
FreightTrain If you are getting rid of your kit, and the coil and high voltage wire is good, I would like to try one last time to get mine working. It seems I have fire at the coil, but it is not strong enough to fire the plug, after replacing the coil and trying 4 plugs, I don't know what to do. Maybe the wire's bad, who can say. Anyone got a video of what the spark on the plug should look like?
And i see I'm not the only one to spray ether from the driver seat! just a little!!
OPCOM
27
Dallas, Texas
That's an interesting question. The pump and coil run any time I throw the switch. Where is ther sensor?
