- 2,092
- 47
- 48
- Maine USA
I am removing the flame heater in order to install the either start kit. The kit came with three plugs to plug off flame heater parts removed. So far I have removed and plugged the two ports on the intake elbow, re-used the jam nut on the plug for the fuel nozzle opening. The final plug goes in the front of the IP. Just want to make sure that I am proceeding correctly. Here are some pictures of the plugs installed, and of the IP where I believe the last plug should go. Want to make sure of the IP plug as its a tight spot and having to do it twice would not be fun, especially in this cold weather. If you have done this conversion I would appreciate your input.
