flame heater valve leaking
sn8ke8
Saginaw, MI
my flame heater valve is leaking on my deuce, drop by drop continuously, its the valve with two plastic red lines going to it, one goes to the fuel rail, any suggestions, can i rebuild it, replace it?
thanz for any info david
where would i get rebuild parts or replacement parts?
cattlerepairman
3,305
NORTH (Canada)
The usual vendors have parts. Common wisdom is, unless you need to start in way below freezing on a regular basis, to simply disconnect and plug the flame start system. It can leak internally, dripping fuel that ends up thinning your engine oil. One day I will do what I say here and disconnect mine. Has not been leaking so far.
wsucougarx
65
Washington State
That's one of those parts that will eventually leak. There are two little O-rings inside the housing that need to be replaced. On my '88, it started to leak on my hot turbo. To remedy a temp fix, I shot some brake cleaner on the end, dried it, and jammed some RTV on the leaky end. That was some 2 years ago and it's still holding;-)
