Keoni_M1123
- 1
- 1
- Kauai, HI
Searched for a few days here and could not find this particular issue:
2003 M1123
Only LED are headlights
Flashers stopped working a few weeks ago. Headlights, running lights, stop lights all work.
After research, bought new control switch. Did not solve problem. Next purchased a new flasher module. When connected temporarily (not mounted), flashers (turn signals) flashed as normal as well as all running lights, headlights, stop lights etc.
Once the new flasher module was mounted and connected, flashers no longer worked. However, the signal bulb does come on bright (static "non-flashing") when the control switch arm is in position. The bulb remains on until the control switch arm is moved out of position. This is true for left, right and hazard.
I have 3 control switches one older and two new. They all behave the same.
Any insight is appreciated.
Thanks,
Johnny
2003 M1123
Thanks,
Johnny
