Flashing center running light.
TNriverjet
24
Clifton, TN
I've had many lights start acting like they should if I just take things apart and re-assemble. It seems like connections can become compromised from just sitting not being used. I believe the cab lights are suspended in a rubber mount, so you may want to check the ground wire connection inside the housing since it isn't directly grounded to the cab metal.
