Flatbed on a 5 ton
Russ Knight
1,054
Perry, FL
Thinking about building a flatbed for my 5 ton. I need to haul 20' sections of pipe with it and also need it to be 8' wide. I am considering an 18' length. Do you guys think the extra 4' length will lighten the front end too much when loaded? I may haul up to 7-8 thousand pounds of pipe.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
It depends on where your trunion for the axles is. If its close to center of the load you may be ok. If its off by feet, I'd say no way.
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
No. You will be fine. I have a 16ft LMTV bed sitting in hattiesburg that is a flatbed. Remove your spare tire carrier and itll be flush with the rear of the truck or let it overhang. 7 benji's and its yours.
Sent from my SM-G935P using Tapatalk
