Flexplate rubs original starter
wisconsinz
Duluth, MN
Hey guys,
Had my 27mt direct drive starter rebuilt because I must have improperly installed a new 28mt gear reduction and it chewed up the flexplate while the tranny mechanics were doing some adjustments. Now, for the life of them, they can't seem to install the 27mt with a new flexplate without them rubbing together on the starter housing. I even brought them pages from the TM. They said they've tried everything. Yes, we have the correct bolts. Yes we have the proper bracket. They are recommending another gear reduction with an open face, but I dont see any reason why the original I had rebuilt wouldnt fit properly.
Any ideas??
steelsoldiers
3,968
Charleston, WV
Hard to say for sure without seeing it, but I’ll throw some things out. Is the shop 100% sure they have the correct flex plate? Did the starter rebuild shop machine the mounting surface on the starter for some reason? Has the tranny shop tried to shim the starter?
steelsoldiers
3,968
Charleston, WV
No machining, same housing. Correct flexplate. Yes, they shimmed, but shimming wont move the starter forward.
Hmmm, that is odd. When you said it was rubbing, I thought you meant the inside of the starter nose was rubbing the outside of the ring gear. Is it a good quality flex plate? I have heard of El Cheapo flex plates having the ring gear welded on crooked or offset in one direction. Have they tried flipping the flex plate over and seeing if it still hits?
wisconsinz
Duluth, MN
Starter was around $80 from O'Reilly's. The flexplate can only be put on one way right? The raised rectangular patch (whatever its called) on the plate should be facing the rear right?
steelsoldiers
3,968
Charleston, WV
Yeah, I was thinking maybe they had it flipped around, but the crank snout and the torque converter bolts go into the recesses on the plate so I don’t see any way they could have done that. Does the ring gear hit the starter all the way around or just in certain places?
nyoffroad
674
Rochester NY
Is the flex plate seated evenly and all the way down on the crank? How can you be sure you have the correct flex plate and starter drive gear?
rchalmers3
30
Irmo, South Carolina
Is your torque converter studded or does it have bolts pass rearwards through the flex plate into threaded holes in the converter?
Rick
319cssb
221
Easley SC
Hey i just thought of something what if they pulled the torque converter out and didnt seat it properly? That would cause issues on re assembly
